Which Valve Springs for MMS 229 Cam?
Old Nov 4, 2002 | 09:37 AM
dug's Avatar
dug
Default Which Valve Springs for MMS 229 Cam?
I just bought it used on sunday. Its a single pattern cam with 230 duration at .050" lift and .578" lift ground with 114 lsa. I think its similar to the comp cams XE lobes. Its ground by comp cams.
I was thinking of using 918 springs with stock retainers and setting the rev limiter to 6800rpms. Should this work?
Old Nov 6, 2002 | 11:40 PM
99 Black Bird T/A's Avatar
Default Re: Which Valve Springs for MMS 229 Cam?
Also might want to check out the Rev dual spring kit. I think MMS also sells a dual spring kit too. I know the REV kit doesn't require machining the heads.
What spring pressures does MMS recommend for that cam?
Old Nov 7, 2002 | 06:37 AM
oOoLy's Avatar
I used dual spring with my mms 229 cam .
Adnan
Old Nov 7, 2002 | 11:40 AM
Buckshot's Avatar
I'm just finishing my MMS 5.3 head / 229 cam install. I got the Rev dual springs with them. They are some stout *****. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
