Oil Pressure Gauge
Old Mar 30, 2007 | 10:23 AM
Joker98's Avatar
Default Oil Pressure Gauge
Hey guys...whats the easiest way to hook up an external oil pressure gauge? My gauge vibrates badly at idle only. Through the rpm range pressure is fine. I just wanna eliminate the gauge as the culprit. Hopin its the sending unit since my ls6 intake is goin on in a few days. Thanks in advance!!
Old Mar 30, 2007 | 10:25 AM
99blancoSS's Avatar
Above your oil filter is a fitting that has two bolts hlding it in. You can drill and tap that fitting. You'll see exactly what I mean when you look at it.
Old Mar 30, 2007 | 10:29 AM
Joker98's Avatar
Thanks for the fast reply...I've seen this problem posted a few times on here but im hopin its not the pump. Whats your opinion??
