Fly Cuttin Question
Old Mar 30, 2007 | 08:30 PM
chuckyt1's Avatar
Default Fly Cuttin Question
Has anyone ever used stock valves, with adhesive sandpaper, as fly cutting tools? Even though the valve might be too small, it's seems that with the valve angle and piston travel, if you cut at TDC you would have enough clearance both laterally and vertically.
Old Mar 30, 2007 | 09:06 PM
bigdsz's Avatar
That would be a VERY bad idea. The possibility of getting the abrasive from the sanpaper into the engine is scary.
Old Mar 30, 2007 | 09:12 PM
N4cer's Avatar
Just buy the tool.
