6.0L and LS1 cranks
Old Nov 6, 2002 | 05:37 PM
taqwache's Avatar
Default 6.0L and LS1 cranks
does anyone know what the differents is between the two. ARE told me that the 6.0L was longer for a 4L80E but Valvegod said that the longer ones only came in 99-00. i am wondering if i buy this 2001 6.0L that had a 4L80E from my uncle if the crank will fit. if not then i have to find a LS1 crank to use and that will increase cost. does anyone know for a fact.
Old Nov 6, 2002 | 06:20 PM
gonzo 6.2's Avatar
Default Re: 6.0L and LS1 cranks
Valvegod is correct, what you will find on the 2k1 6.0 with the 4L80E is a spacer between the flexplate and crank, toss the spacer and use your 5.3 flexplate. I have a mint 99-2k 6.0 crank FS any takers?
Old Nov 6, 2002 | 07:30 PM
turbo'd stang's Avatar
So that crank would work fine in a 6.0L block with a 4l60E using ls1 rods/pistons??
What are you asking for it?
Scott
Old Nov 7, 2002 | 08:05 PM
gonzo 6.2's Avatar
the crank i have came out of a 2k 6.0 which the rear crank flange is aprox. .300 thicker,this crank i have is only good for the 4l80E trucks. All 2k1 and up 6.0s use the same crank as the LS1s and 5.3
Old Nov 8, 2002 | 12:07 AM
red53gmc's Avatar
There are different part numbers for each crank from GM, 2001+. I don't know what the differences are.
