What Are These GTP Heads Worth?
Old Mar 31, 2007 | 01:18 PM
zain98's Avatar
Question What Are These GTP Heads Worth?
I have a set of GTP stage 2 806 casting heads that i need some advise on
( 97-98 heads ) None center bolt valve covers
they flow
intake
100 200 300 400 500 600 700
65 139 192 230 256 275 284
exhaust
56 109 151 179 198 210 218
66 cc chamber
They have a fresh valve job, all new seals, 918 springs, and are ready to bolt on.
What do you guys think they are worth?
Old Mar 31, 2007 | 01:22 PM
davered00ss's Avatar
Moderator
806 castings? are they center bolt valve covers? I would say not a lot considering the price drop in the 243 casting ls6 heads. You can get a new set of CNC'd ls6 heads for under a grand. TSP even had a specail with some old CNC program ones for $795. Used ones are going in the $600 range on the board.
Old Mar 31, 2007 | 01:23 PM
bandit4's Avatar
Paper Weights.
Old Mar 31, 2007 | 01:24 PM
ATXCAMAROGUY's Avatar
Above response is right, those flow numbers are more along the lines of stage 1 numbers.
Old Mar 31, 2007 | 04:44 PM
zain98's Avatar
any one else?
Old Mar 31, 2007 | 04:47 PM
Moderator
Oh yeah, non-center bolt valve covers = Paper weights. Sory.
Old Mar 31, 2007 | 04:48 PM
Moderator
I think stock 243 castings flow that good or better and can be had for $300 on the board, $500 with new 918 springs.
Old Mar 31, 2007 | 06:03 PM
DrkPhx's Avatar
GTP does some good work. Those sound like older, ported heads.
Old Mar 31, 2007 | 07:17 PM
Hard Core Z28's Avatar
Pass them up. Much better heads out there now a days.
