question on Yella Terra Ultra Lights
Old Mar 31, 2007 | 04:21 PM
Screamin_Z's Avatar
Question question on Yella Terra Ultra Lights
I'm going to be installing these beauties tomorrow after I change a few things on the engine that's going on today. the question I had was there are 2 little drill starts in each shaft between the rocker arms. I read thru the Yella Terra instructions and I read the instructions on ls1howto but no info on this...what are those to marks for? Is that a mark showing which way it needs to be installed (facing up or down)?
Hope someone has the answer before tomorrow morning, thanks guys.
Old Apr 1, 2007 | 10:49 AM
Screamin_Z's Avatar
no one? I don't even know if it means anything, I just want to make sure before I install...I've got a few more hours before I install so I'll check back before then.
Old Apr 1, 2007 | 10:54 AM
PREDATOR-Z's Avatar
I think Patrick G has those, PM him.
Old Apr 1, 2007 | 01:36 PM
Screamin_Z's Avatar
thanks predator
Old Apr 1, 2007 | 05:58 PM
Smitty's '04 GTO's Avatar
I checked mine after reading your post, and have the same thing. I can't see that they'd serve any functional purpose as it pertains to installation or operation. My guess would be that they were machined like that perhaps to allow a tool to hold the shaft while assembling the pairs of rockers during manufacture?
They can only be installed with those divets up or down so it's a 50/50 proposition. My plan is to pick one (probably up) and do all 8 pairs the same...
Good Luck with it!!!
Old Apr 4, 2007 | 03:35 AM
LS1267's Avatar
Hi Guys,
The markings you are seeing are internal manufacturing identification marks and serve no functional purpose. Some engine builders use the id marking upon installation as a reference and rotate the shafts occasionally to even wear under extreme conditions.
Hope it clears the confusion....we'll be posting something up on the webpage becuase it is a common question....
Jim
YELLA TERRA
Old Apr 4, 2007 | 02:21 PM
cowboysfan's Avatar
all makes sense now.
Thanks Jim
