i need some numbers, help pls.
Old Nov 10, 2002 | 11:51 AM
BYBYC5's Avatar
*Bad Trader*
Default i need some numbers, help pls.
ok im want to offset grind my crank (3.72) i want to use my stock pistons, what size( length and bearing cap) do i need.) ive decided to build a 6.0 iron block with the stock pistons and offset grind my 5.7 crank. i just want to know what rods and where i can get em
Old Nov 10, 2002 | 06:57 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: i need some numbers, help pls.
ttt
Old Nov 10, 2002 | 08:31 PM
TimZ28's Avatar
I would recommend going with new pistons with the appropriate compression height rather than replacing the stock rods. You will be spending alot of $ replacing rods and buying yourself very little.
Tim
Old Nov 10, 2002 | 09:00 PM
BYBYC5's Avatar
*Bad Trader*
ok so do i get new rods and pistons or just pistons and use stock rods??
Old Nov 10, 2002 | 09:10 PM
TimZ28's Avatar
You can keep the stock rods.
Old Nov 10, 2002 | 09:11 PM
BYBYC5's Avatar
*Bad Trader*
ok stock rods, 3.72 stock crank. how do i find out what pistons i need???
Old Nov 10, 2002 | 11:11 PM
DONAIMIAN's Avatar
your pistons have to be custom made. when you call in the order for them, tell them all the info about your engine.
