cam recommendations??
What do you want out of your cam? Is it an auto or manual? What stall and /or gear do you have? Do you drive in traffic?
The LS6 and FAST manifolds are tuned for a peak of 6300 rpm, so putting in a cam to make power much over that is somewhat of a waste, and generally trades low end that you really feel in a driver.
I think one of the best street cams out there is a 228/232 110+1 custom grind. The VE's are right on par with the intake tuning, and it still makes plenty grunt where you can use it.
That cam I listed should work well, and I wouldn't see any reason to go bigger. If you do a lot of city driving, and you don't want to run a stall, I'd say stick with one of the 224 cams, like a TR 224 or TSP 224R.
Question for you - how much weight removal did you have to do to get to 2800 lbs? I've always thought a LSx powered Malibu would be the hot ticket. My first car was an '81 Malibu with a 355. Yours looks much nicer.
Good luck!
the malibu in my sig had an LT1/6speed, hopefully next year ill start working on a LSx motor for that too...
