Finished my Cam Install
Old Apr 1, 2007 | 02:47 PM
1LE4ME's Avatar
Default Finished my Cam Install
I had spring break this week from BSU, and I had a cam install scheduled. It took longer than expected, but I got it done in about 3.5 days. I installed a TR 224/224 112 LSA. It started right up and I can feel the extra power. I wanted to ask if I should drill the hole in the TB to a larger diameter, I drilled it to 3/16. Should I drill it to 13/64 because the car surges sometimes. I drove through a parking lot with speed bumps and the car was jerking at the low speeds. Other than that, the car seems to work fine. It revs to 6 grand with ease. I'm eager to go to the track to see if I have 12's. Any estimates on HP or trap speeds?
Old Apr 1, 2007 | 02:56 PM
JPH's Avatar
JPH
NO, just get it tuned as soon as possible. the tuner will correct the idle for you. you shouldn't had to even drill it anyway.
Old Apr 1, 2007 | 03:07 PM
TRU-2GM's Avatar
^^^^ what he said...just get it tuned...nothing else.
Old Apr 1, 2007 | 03:11 PM
bastien's Avatar
Get your car tuned. The first dyno pull after my cam install, untued, was VERY rich and dyno'ed 330rwhp..
