GMPP "Caddy" Lifter Install Q
While tearing the LS1 apart in my GTO last week, I paid attention to and noticed that the oil feed holes were not uniform in their orientation during factory assembly. In my engine, 10 faced up towards the valley, and 6 faced down towards the oil galley. This leads me to believe that it doesn't matter about the orientation of oil feed hole, which may make the following question moot...
Now, one of the differences of the GMPP "Caddy" lifter (GM part# 88958689) is that the oil supply hole in the side of the lifter is located 90* rotated from the stockers. This means that the lifters can be installed with the oil supply hole facing either the front of the engine, or the rear. Anybody know which would be best? I'm guessing the front, as I think the oil is supplied via the oil galley from the front of the engine, where the oil pump is located.
Anybody got any other thoughts on this subject? Maybe I'm just "overthinking" it?
Would especially like to hear opinions of experienced engine builders, or those who've already installed these GMPP "Caddy" lifters... but all responses welcome!
Thanks!
https://ls1tech.com/forums/generation-iv-internal-engine/580686-new-upgraded-hydraulic-roller-lifters-sdpc.html
Anyway, FYI, the oil from the oil pump is sent to the rear of the block, through the filter, then up from the filter up to the lifter galleys. (Travels in the lifter galleys from rear to front)
https://ls1tech.com/forums/showthread.php?t=580686
Yes, positive. My stockers are different to those pictured in the link you posted. My stockers have the oil feed hole in the side above the face of the roller wheel. Also, my stockers do not have the body of the lifter surrounding the roller wheel but rather come down along the sides of the wheel like a pair of bicycle forks (another reason I think the GMPP lifters should be better / stronger than stockers...). I tried to take some pics, but they didn't turn out too well.
Anyway, thanks for the info about oil in lifter galley travelling from rear to front, I will orientate my lifters all with supply hole facing rear of engine, as another poster did. It probably doesn't matter as the oil under pressure surrounds the lifter in that center section of the body and like I mentioned, my stockers were mixed top and bottom as to which way they were facing when I pulled them, and they were assembled this way from factory...
Thanks much for the help guys!
http://memimage.cardomain.net/member...geQuality=Full
Yes - the oil will just flow around the body of the lifter and make it to the hole no matter what. You can see this if you look at the comparison picture.
