Is this Block Salvage-able?
Old Apr 1, 2007 | 10:32 PM
Flipn's Avatar
Default Is this Block Salvage-able?
Ok.. im a n00b and im trying to learn and do alot of the work myself with the help of some friends with experience.. Anyways, I was cleaning the threads on the block for the heads (using the LS1howto.com method) and one of the bolts broke in the block..
Now, I've tried 2 different "bolt back-out" kits (ones that u drill a little hole then use a hammer to tap the bolt then back it out) and none of them worked. It just kept getting stripped so we decided to just drill it out.. it looks like this after we finished.. Is this Salvage-able?
Attached Thumbnails Is this Block Salvage-able?-ls1-0011.jpg   Is this Block Salvage-able?-ls1-0041.jpg
Old Apr 1, 2007 | 10:53 PM
Grimes's Avatar
bring it to a machine shop and get a helicoil installed. I think you can salvage it.
Old Apr 1, 2007 | 11:25 PM
Flipn's Avatar
Thanks for the TIP.. Im asking our local forum now for machine shop suggestions.. I also looked up Heli-coil inserts and its just an insert to increase the size of the threads to match the new tap..
Old Apr 2, 2007 | 07:11 AM
brad8266's Avatar
Yep use a helicoil and youll be good to go. The helicoil is usually stronger then the original threads too.
