Problems with new engine: Low Oil??
Well i put a quart in, another and on the dip stick it reads in range now (2 quarts!?) get in and start it up and the low oil light is still on??
ANy ideas? did a pump go out not letting it circulate?
The car is turbocharged with a new engine with 3,500 miles on the new engine.
You may be eating oil throught the intake tract. My Turbo Tech kit was bad about that until I did some rerouting of the PCV lines. The problem is that the PCV line actually runs down to the intake side of the turbo (right after the air filter).
This results in major oil suckage into the intake tract. If you pull off your intake tube right before the MAF, and there's lots of oil in there, this is likely you problem.
It didnt seem like it was consuming oil, ill check to see if it has oil on the throttle body to make sure.
i dont think it was 2 quarts low, cause now its over full, ill have to drain some out. might have been 1 quart low.
Guess its very possible its my PVC system, i havent put the pvc filter inline yet. but 1 quart in 2000 miles does that sound right?
<small>[ November 12, 2002, 08:24 AM: Message edited by: smokinHawk ]</small>
Todd im not sure about the PVC lines by the air filter. I dont think mine has any pvc line coming into the intake untill the throttle body or in the intake what ever one it goes in at. thats the only one i know of.
Todd
