Freeze Plug question
Old Nov 12, 2002 | 10:04 AM
AllCammedUp's Avatar
Default Freeze Plug question
What conditions must exist for a freeze plug to pop out of the LS1? I know it must be below 32* F <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> , but what else? Will they pop out if there is no coolant in the block and it's below 32*F?
I'm changing my heads/cam and I might not get to the point of filling the radiator before we have a couple of 32 or below nights here in Louisville. Will I run a risk of having the freeze plugs pop out?
Thanks. I know this is probably pretty basic stuff, but it's the first time I've ever been faced with it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 14, 2002 | 03:43 PM
Superman's Avatar
Default Re: Freeze Plug question
Freeze plugs don`t "pop out" at least not an an LT1 or LS1. They are there to be screwed out to let any remaining fluid out of the block.
Took a good impact gun before mine loosened up.
Old Nov 14, 2002 | 05:15 PM
FastAl's Avatar
My understanding of freeze plugs is that because there is no water/coolant in the block, then nothing will happen. It is the pressure ice creates because it expands when the water freezes. The freeze plug is just a weaker metal to go first instead of the whole block!
Old Nov 14, 2002 | 05:26 PM
minivette's Avatar
Yeah, they are there to keep your block from cracking as a result of freezing temp's cold enough so that your antifreeze fails.
Old Nov 15, 2002 | 12:00 AM
ok guys, I understand now. Thanks for the replies, as that clears it up!
Old Nov 15, 2002 | 12:35 AM
