Tr224/112 vs Tr224/114
Old Nov 19, 2002 | 03:00 PM
RoyO's Avatar
Default Tr224/112 vs Tr224/114
I consider myself reasonably smart and Ive been reading all of the posts,but does 2 degrees of lobe separation angle make that big of a difference with these cams? I notice the A4 guys go with the 114lsa and the M6 guys go with the 112lsa. I dont wanna seem uninformed or stupid but does this have something to do with programming between the cars or the converter.Thanks for helping me clear this up.
Old Nov 19, 2002 | 03:12 PM
mrestrictrplate3's Avatar
Default Re: Tr224/112 vs Tr224/114
al tuners recommend he 112 fr m6 cars so the powerband is lower, the 114 they recommend for the auto cars. the 2 degrees will make a differencein the powerband for sure.. just think if u had a 226 degree at 50 duration cam and how much choppier the idle would be. im sure someone can explain it better than i can
Old Nov 19, 2002 | 03:27 PM
niphilli's Avatar
Yes, the 112LSA will peak a little sooner but I think the reason they reccomed a 114 for A4 cars is because of idle quality. It is harder to get an A4 car to idle with a choppy 112 LSA cam.
Old Nov 19, 2002 | 03:29 PM
Chris99WS6PWTMET's Avatar
A 114 will idle much better in an A4 than a 112 will. The 112 will work fine though with tuning in an A4. I have the 114 in my A4 and love it. It has a smooth idle but not alot of lope to it. If you want radical thump then I wouldnt advise the 114. I shift it around 6600 and its brought me to a best of 12.07 @ 113 on Nittos, lowered, 3.73's, LS6 intake, shorties, and SY3500. I dont think you can go wrong with either grind though. I have read very few complaints on either of them.
Old Nov 19, 2002 | 03:57 PM
SSLink's Avatar
I agree completely with the other guys regarding idle quality. The greater overlap due to the tighter LSA lowers manifold vacuum causing a rougher idle. 2 degrees in LSA make a big difference.
Other specs being equal, a cam with a tighter LSA (e.g. 112 vs. 114) in the 220 degree range in intake duration will give you higher peak torque and more torque throughout the 2000-5000 RPM midrange than a cam with a wider LSA. HP theoretically falls off a bit faster past peak.
Essentially your powerband is peakier, comeing on stronger, faster and tapering off sooner.
A tigher LSA is great on an M6 because you can really feel when you're "on the cam" and in your sweet spot. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 19, 2002 | 08:58 PM
pepto's Avatar
these cams are ground with 4 degress of advance built in. degree the cam in with 2 or 4 degees retard to change intake center line and idle changes so does power band.
