LS1 intake holding me back?
Mods are:
"the bolt-ons", FLP long tubes, B1 cam with programing, and bone stock heads.
The car was dynoed with the cats on at 6200 rpms unfortunatly at 360rwhp/349tq. I read here most people are reving up to 6500 or even 6800 rpms.
What I'm asking is if taking it up to 6500 rpms and an ls6 intake with the off-road pipes on will squeeze out 20 rwhp.
I ran the B1 cam about 2 years ago and pulled 375/362 with Grots w/ off-road, all the bolt ons, and stock LS1 intake.
Just because you rev to 6600 doesn't mean that your peak HP is made there. With a peak HP at 6200 you'd probably be shifting at 6600. So, you're fine there.
Dyno's can vary...ALOT! Dyno numbers from different dynos on different days should not be seriously compared. You may be just a different dyno away from a 20 HP gain.
The LS6 intake would probably be worth no more than 10 HP to you with those stock heads.
If those are FLP cats they aren't costing you more than 3-4 HP.
So, add it up. 3 here, 10 there, different dyno, a little tune tweaking, and you've got your 20-30 HP increase. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
