Lifter install direction??
Will it hurt to turn a lifter around 180* in a lifter bore on a LS1, no it wont. Will it hurt to move a lifter from one position to another, probably not. But its attention to detail that goes a long way building a reliable engine. The lifters on a LS1 are cut in such a way that oil will travel around the recess in the lifter to the oil hole no matter what the position. I'm trying to remember that I think I saw a document that GM put out saying when you install new lifters, try to orient the hole in the lifter to the oil passage in the block. I can't find anything in the service manual and TSB's tonight. I'd say if you didn't mark the position when you took them out, orient them to the oil passages in the block, that way they can pump up a fraction of a second quicker and will be less affected by varnish buildup afer you get some miles on that engine. Hope I've helped you out some. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Jay
<small>[ November 20, 2002, 10:53 PM: Message edited by: JAY4SPEED ]</small>
