pick my cam
Old Nov 20, 2002 | 11:01 PM
Jim's Avatar
Jim
Default pick my cam
Any advice?
Mods;1 5/8 Grots,ST3500,ASP,portedT.B,Gran maf,373s PCM already tuned.Heads will be going on too.2002 stock heads,shaved.030,TT retainers,Comp 918s,7.35 hardened pushrods,keeping stock vavle size,local speed shop hand porting.Also,what head gasket do I need to take full advantage of the shaved heads?I'd like to shift at about 6500 as the limiter is already at 6800.I do not care about rough idle,the rougher the better.As I stated above,the PCM is out of my old H/C car,so the idle is sitting at 1000 rpms in gear.
I thank u in advance for any help.
Old Nov 20, 2002 | 11:08 PM
ExtremeZ28's Avatar
Default Re: pick my cam
im thinking yer classic 224/224 grind from Thunder Racing or even LS1speed.....112 if you want a nice choppy idle and 114 for decent choppieness just not as choppy <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 20, 2002 | 11:36 PM
Brother J's Avatar
Another vote for the TR224. Since you have an A4, go with the 114 lsa.
