engine missfire and running flat after new cam....
Old Nov 21, 2002 | 05:24 PM
Phil99vette's Avatar
7 Second Club
Default engine missfire and running flat after new cam....
I just installed my new cam and am getting a missfire code. What is the easiest way to determine if its false and how do you fix it? I am running 11.75:1 cr with a pretty big cam on 93 octane gas, is this gas sufficient or should I step up to higher octane?
Phillip
Old Nov 21, 2002 | 06:31 PM
jmX's Avatar
jmX
Default Re: engine missfire and running flat after new cam....
What cylinder is the misfire showing up on when you connect a scanner? All of them or just one?
Old Nov 22, 2002 | 11:31 AM
7 Second Club
I dont have a scanner but I'll call a guy at work and see if I can get one tonight or tomorrow. I have heard that alot of these big cams with tight LSA's normally trigger false misfire's.
Phillip
Old Nov 22, 2002 | 02:29 PM
LOnSLO's Avatar
FWIW, after my cam install, I was throwing P0300 codes all day long. (random misfire). Common with cam swaps. If it turns out to be just one or two cylinders, then I would do some investigating. LS1 edit will clear the p0300 code forever.
