Check out this NEW valve spring removal tool >
Old Nov 21, 2002 | 05:41 PM
Tin Indian's Avatar
Default Check out this NEW valve spring removal tool >
Well, I don't think Moore Performance is a sponsor here, but when a neat tool like this comes out, I think it's of interest to us anyway.
Take a look at this valve spring removal tool. Works on any 3/8" drive socket wrench. A little pricey, but may save alot of time for in-car spring removals.
<img src="http://www.moreperformanceinc.com/images/heads_12.jpg" alt=" - " />
<img src="http://www.moreperformanceinc.com/images/heads_16.jpg" alt=" - " />
Anyone use one of these yet?
Ron,
________________________________________________
<small>[ November 21, 2002, 05:46 PM: Message edited by: Kimchee and Rice ]</small>
Old Nov 21, 2002 | 05:49 PM
Hugger's Avatar
Default Re: Check out this NEW valve spring removal tool >
How much does it cost, can you give us a link?
<small>[ November 21, 2002, 05:53 PM: Message edited by: Hugger ]</small>
Old Nov 21, 2002 | 05:52 PM
Tin Indian's Avatar
Every bit of a hundred dollar bill and a twenty dollar bill ! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
ls1290's Avatar
Dumb Ass Vette Moderator
I LIKE IT! Where can one buy one of these?
Old Nov 21, 2002 | 05:54 PM
Tin Indian's Avatar
Just like I said above...
Moore Performance
Old Nov 21, 2002 | 11:23 PM
Bink's Avatar
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> has anyone tried using this??
Old Nov 22, 2002 | 08:06 AM
TATERBUG01's Avatar
Since I am in Charlotte, thought about buying one just to rent out to all my buds <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Nov 22, 2002 | 08:24 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
www.more performance inc.com (take out the spaces <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
Old Nov 22, 2002 | 10:53 AM
Scalpel's Avatar
That is probably one of the most brilliant tools I have ever seen. You could do a spring swap in less than 1.5 hrs with that <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 22, 2002 | 11:40 AM
xaon's Avatar
I purchased this tool last week to use to change out my dual springs with the heads on the car, being as they're damn near impossible to do with a standard crank-down type compressor that we usually use on our vehicles.
I have it here sitting on the desk waiting for me to use it this weekend. It was a bit on the expensive side ($129), but if it's ease of use is ANYTHING better than the snap-on compressor I used last time, it's worth every penny.
I had planned to report on how well it worked for me after my spring re-install, and will do such at that time. So look forward to a future post on the subject.
Old Nov 22, 2002 | 01:17 PM
Scalpel's Avatar
xaon, kick *** man. Please let us know how it works. I guarantee it is MUCH easier.
Old Nov 22, 2002 | 05:30 PM
Black Magic's Avatar
I have used it. The thing is awesome for spring removal, but not so good for re-installation. It's hard to get enough leverage on the spring with one hand, and still line up the keepers with the other hand, and make sure the retainer doesn't drag on the valve. I finally chose to use the More Performance tool to remove them, and my Craftsman screw type to reinstall them.
Overall, I say it's worth the money if you do a lot of them. But if you only plan on doing one spring swap, use the standard type compressor. I use the one from Craftsman.
Old Nov 23, 2002 | 10:18 PM
xaon's Avatar
I used mine today to remove and reinstall a set of REV-1116 Dual Springs. All I can say is it was worth EVERY penny!
A few notes I had about it.
1) Work only with a max of about a 6 inch extension (I think I used a 6 inch extension for the back 2, and a 3 inch for the 3rd from the back), anything more than that and it's wobbly at best. For most of the springs I used the craftsman ratchet stuck right into the side of it, and then stuck a 2 foot long cheater pipe over it. It made it a peice of cake. I could pull down the compressor with one hand, and with the other hand easily put the two keepers in.
2) You can do almost all the springs one-person. I found it even difficult to have one person operate the compressor while another installed the keepers.
3) If you're using single springs, a Normal crank-down style compressor will probably work just as well, if not better (though your hands may feel better at the end of the day with the lever-style... mine sure as hell do). The more performance style compressor is a little time consuming due to having to unbolt and bolt down the compressor in each rocker arm boss. For dual springs on an f-body, this compressor takes the pie hands down though. Now if only a quick-attach/quick-release fastener for the compressor could be had... HMMmmm....
P.S. Anyone want to buy a Snap-On crank down style spring compressor? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 24, 2002 | 12:22 AM
35th SS's Avatar
have one of those on hand but havent used them yet.will post at a later date. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
