Stock LS6 heads install question
Old Nov 22, 2002 | 12:02 AM
Lefty's Avatar
Default Stock LS6 heads install question
What gaskets will be needed to install stock 02 LS6 heads & Manifold on a 99 SS. I do know egr will need to be blocked. And can you tell me what else is needed to do the swap.Gaskets etc? And any tips & suggestions that I need to know.
Mostly stock 6-spd.1999 SS. Just FRA,FTRA,WhisperLid,K&N,SLP Fan Switch,
So what kind of power Gains should I expect from the stock ls6 heads & manifold now?
I do plan to go w/FLP's and TR 224/112 Cam come spring.
Thanks in advance.
Old Nov 22, 2002 | 10:04 AM
Raughammer's Avatar
D(irecto)r Pepper
Default Re: Stock LS6 heads install question
Just use the stock gaskets... and isntall them.
There should be no issues...there were none for me.
