Pushrod length question
Old Nov 22, 2002 | 10:40 AM
LS1 BU's Avatar
Default Pushrod length question
I have a comp XER grind cam and 5.3 liter heads milled .010. I've been told that the base circle on the cam is .030 smaller. I would assume I would use a 7.40 pushrod. Is this correct??
Thanks for your help
Old Nov 22, 2002 | 01:07 PM
Paul F's Avatar
Default Re: Pushrod length question
That would be correct. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 22, 2002 | 08:12 PM
LS1 BU's Avatar
Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 22, 2002 | 09:28 PM
Redline-Motorsports's Avatar
Isn't the stock pushrod length 7.400"?
Old Nov 22, 2002 | 10:14 PM
Tin Indian's Avatar
yup...
Old Nov 29, 2002 | 09:14 AM
2001 Pewter WS6's Avatar
Restricted User
I thought the stock push rod legnth was 7.375" not 7.400"
Old Nov 29, 2002 | 10:41 AM
TimZ28's Avatar
I have an XE-R grind and stock heads milled 0.015". I went with 7.350" pushrods. The 7.400" pushrods were preloading the lifter ~0.080". Comp recommends ~0.030". I wouldn't take anyone's word on this... do it right and check the preload on your setup. In fact the base circle is different between my intake and exhaust lobes on my cam.
Tim
<small>[ November 29, 2002, 10:42 AM: Message edited by: TimZ28 ]</small>
Old Nov 29, 2002 | 03:30 PM
DONAIMIAN's Avatar
get a pushrod length checker, better safe than sorry.
