camshaft loping
Old Nov 24, 2002 | 02:34 PM
LS1 Brent's Avatar
Default camshaft loping
is it possible for a cam to make a stock LS1 engine "lope"? and if so what kind?
Old Nov 24, 2002 | 02:58 PM
LS1derfull's Avatar
Default Re: camshaft loping
Lope is caused by cam change, is that what you mean? Lope is caused by exhaust gases polluting intake charge at low rpms. The more duration each cam lobe has and the tighter the lobe seperation, the more noticeable the lope is.Sharp head porters can lessen this effect by changing radius and angles on valves and also port technique on exhaust port. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 24, 2002 | 03:19 PM
LS1 Brent's Avatar
thanks for the info. this will help me on purchasing a new cam.
