What do you recommend with this....
First of all, what do you guys think of this cam?
Second of all, what kind of heads will compliment this cam?
Why will using cometic thinner gaskets work better?
What are the drawback of using a thinner gasket, is durability an issue?
I will definately want to up grade!!
What kind of Push rods should I get?
Will I need different lifters?
what kind of valve springs?
I will appreciate your comments, and suggestions. I know they are alot but i just want to know what you guys are using, and what has been holding up and what hasn't, cause I just want the good **** for my car. thanks
-Any head will work with it.
-Thinner gaskets will tighten the quench area of the combustion chamber, which will help in reducing detonation. the thinner gasket will also raise the compression ratio some.
-Durability is not an issue with a thinner gasket.
-Stock PR;s should work i would imgaine since its a GM cam.
-Lifters are not needed.
-You will need an aftermarket spring or at the very least the Z06 springs.
The hotcam is a good cam. It will make pretty decent power and you wont suffer much with gas mileage...but you will definitely need to get the car tuned. The hotcam sounds and acts much bigger than it is.
Is a 7.4 right? Or should I perhaps be going with a 7.425? Also, I've got new LS6 springs, and a set of Dart head "take offs" which behave a lot like 918s from what I understand. I believe they were a brand called PSI? Anyway they have about a hundred passes on them...got them for free. Which spring? I am leaning a little more toward the LS6 since they're new and the specs of the PSIs are a little unsure to me. I am very inclinded to believe that they're identical to 918s because I got them from a very reputable member here.
Wacha think?
Wacha think?
The best heads have shown significant increases in power even with stock cam so they will help yours. Just a rough guess but the .040 gasket combined with 62cc heads will boost CR to something like 11.2x or 11.3 and DCR to 8.5 depending on advance of the cam.
The LS7 lifters are just better than the stock LS1 units...the caddy ones are the lightweight racing version but double the price.
The hardened PR are the only way to go if you are going to have the engine apart anyway, cheap insurance.
The 1.85 rockers will increase the final lift numbers of the cam.
The 918 springs are...(self-explanatory)
Just my $0.02
http://www.carcraft.com/howto/ls1_engine_cam_install/
GO BIGGER DAMN YOU!!
