advancing a cam
Old Nov 25, 2002 | 09:31 PM
jason hamilton's Avatar
Default advancing a cam
Could someone please explane to me why you would install a cam and advance it x deg.? what is the purpose? thanks .
Old Nov 26, 2002 | 08:34 PM
wrencher's Avatar
wrencher
Default Re: advancing a cam
A cam has a usable power band= example 2000 - 6000 rpm There usually is advance ground in from mfg. to compensate for timing chain slack. If you advance this cam the power band will begin at a lower speed & fall off ealier at high rpm's.If you retard this cam it's vice versa. Haven't messed with alot of ls1's yet but most others you move 1 degree it shifts power band 500 rpm . This is the purpose for a cam card so you can degree in the cam & modify from there if you want.
Old Nov 26, 2002 | 08:37 PM
wrencher's Avatar
wrencher
Dang typo's that's 50 rpm's my bad!
