Smoking at idle
Old Apr 7, 2007 | 10:12 AM
v8blazer's Avatar
Default Smoking at idle
Just did a cam install with the dual springs etc. The first few days after the cam install there were no problems. Had the car put on a dyno, and it made decent numbers, and had a A/F @ 12.9. No after that the car started to smoke a little at idle or when letting off the gas, but does not smokeunder WOT. It is obviously oil. I'm leaning toward it being a valve seal(s) that I didn't seat properly, and they eventually lifted from the vacuum causing it to smoke at idle and not WOT. It hasn't burned a lot of oil, but the smoke is visible when standing outside of the car. Am is my thinking in the right direction? More trouble shooting ideas etc.?
Old Apr 7, 2007 | 11:32 AM
staringback05's Avatar
i might also lean towards a valve seal, what does it do when you let it sit for a while and then turn it on?....
Old Apr 7, 2007 | 07:12 PM
v8blazer's Avatar
Before the cam it would have a slight puff of smoke on start up, but never anything at idle. What would be the best way to check valve seals?
