Lifter Question
Old Apr 7, 2007 | 01:49 PM
tilly's Avatar
Default Need to check Lifters
Hello,
IS there anty qway to check my lifter to seei f they have failed without taking the heads off the car. Could I pull the valley cover and check them that wayt or does the head completely bolt over the lifter itself.
Tilly
Old Apr 7, 2007 | 09:56 PM
tilly's Avatar
is there a way to inspect the lifters wit the heads still on the engine ?!?!?!?!?!?
Old Apr 7, 2007 | 10:10 PM
marv's Avatar
There's really no good way to look at them and truly inspect them without pulling the heads.
I guess you could look down the PR hole in the heads, but that's not going to tell you anything.
Old Apr 10, 2007 | 09:26 AM
tilly's Avatar
hmmm, thank you. I figured as much.I just wanted to make sure there was an easy way of doing it before I tear down a good chunk of that motor.
Old Apr 10, 2007 | 09:27 AM
brad8266's Avatar
Heads need to come off for anything lifter related pretty much. You could check for a completely collapsed lifter though by pulling the valve covers and push on the push rods and fell for a weak lifter.
