with a 233/239 cam or TSPv3 torquer?
how much low end did you lose because of your LSA?
So if that is the case. what would put me @ 470 WHP with a bigger cam and what heads to go along with them? I just keep getting greedier and greedier with power.
I want to run a cam in the low 230 intake range and mid to high 230 exhaust range...
If I went with a texas speed head and cam package, what cam I match up to achieve the 450RWHP minimum mark... 470 RWHP is fine too!!
The only reason I want a cheap had and cam setup is because I have 85,XXX or so mile son my motor now and I plan on running this setup for only a good 20,000-25,000 miles, until I get a new block and another set of new heads and another cam. SO this will be a temporary setup for a year to an estimated 1.5 years..
also what rearend are you running stock 10 bolt or something else.
With a good head selection to compliment either cam, you should have know problem seeing 450+ rwhp. Of course you are still going to need a really good tuner.
