what does a broken valve spring sound like
Old Nov 30, 2002 | 07:05 PM
MARKSZ71's Avatar
Default what does a broken valve spring sound like
hey guys need a little help here on my 98 ss. We just installed gtp heads and a 224 224 112lsa cam after my first pass the motor developed a loud ticking noise checked the rocker arms everything fine there, its starts when the motor has some heat in it, she runs and pulls hard so a valve spring or a bad lifter??????????????
Old Dec 1, 2002 | 02:37 AM
DONAIMIAN's Avatar
Default Re: what does a broken valve spring sound like
If they're the oe lifters, how many miles on the car <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 1, 2002 | 10:14 AM
MARKSZ71's Avatar
oe lifters around 70000 miles on them yeah i guess i should have replaced them
Old Dec 1, 2002 | 05:44 PM
kick_*ss's Avatar
If you suspect a broken spring its easy enough to remove the valve covers and check. If you have any doubt at all, open it up and check. I did not know I had a shattered seat and luckily since I change my own oil I saw the broken pieces.
It was running very strong, and sounded great. Go figure. But I opened it up and there plain as day a broken seat on cylinder #2 intake seat was shattered.
