LARGEST cam without missfire codes (stock tuning)
Old Dec 1, 2002 | 08:57 PM
wrencher's Avatar
wrencher
Default LARGEST cam without missfire codes (stock tuning)
Just like it says, Even with a 112 or 114 I wondering what can be gotten away with for emissions testing reasons. T.I.A. for any replies!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 1, 2002 | 09:58 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: LARGEST cam without missfire codes (stock tuning)
TR 220 on 114=I never threw a code.
TR 224 on 112=Will throw a code on cold startup(misfire)All I do is keep it revved to 1500 rpms for about 30 seconds on cold start and the engine light never comes on.Any other time(hot starts)=no problems.
Old Dec 2, 2002 | 12:20 AM
xaon's Avatar
I have a Comp Cams 224/224 .581/.581 112lsa cam on my 01 M6. I have never thrown a misfire code because of the cam. (Only time I threw misfire codes was when I broke 2 valve springs resulting in many misfires on 3 cylinders.)
I believe some ls1edit tuning will eliminate the misfire codes in the event you do throw misfire codes.
Old Dec 4, 2002 | 08:48 PM
wrencher's Avatar
wrencher
Thanks for replies, <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> anyone else?
Old Dec 4, 2002 | 10:06 PM
MyLS1Hauls's Avatar
It all depends on how you drive the car. If I let my cam in sig idle too long from a cold start, it will set the SES light for a P0300 code. It's an XE profile even, which helps it idle better.
Old Dec 5, 2002 | 09:52 AM
T/ABlast69's Avatar
i have a 218/224 114 lsa. i threw po300 only on real cold start up, with stock tuning. Its worth it with that cam.
Old Dec 5, 2002 | 10:02 AM
bae_98Z's Avatar
I have a 222/.563/114, and I throw a code only if I idle for over 5 minutes.
Kyung
