Main and rod bearing clearances??
Old Dec 3, 2002 | 02:13 PM
oOoLy's Avatar
Default Main and rod bearing clearances??
Hi,
Does any one know how much clearance I should have on my main and rod bearings. Im building my short block and want to make sure everything is in spec. Any help will be appreciated
Old Dec 3, 2002 | 05:33 PM
LS1swap's Avatar
Default Re: Main and rod bearing clearances??
Mains .054 mm (0.00212 in)
Rod .015-.076mm (.0006-.003 in)
Do you have a manual???? They need to be torque in sequence to spec to measure with plasti gauge get the green .001-.003 cost about a $1 per strip... I would get at least two.
