What should I be running after cam install?
I'm having TR cam 224-224-114, LS6 intake, ASP crank pulley,NGK tr6 plugs, Taylor Thundervolt wires and custom tuning installed.I can't use the n20 off the line now because I don't have a cage. I'm wondering if I'll hit the 11's n/a after everything is installed. My installer says if I switched to slicks I would probably hit 11's.I'm afraid of the 10 bolt though.What do you guys think?
Thanks, Jay
50 rwhp should get a reduction of 5 tenths and add 5 mph.
I don't think Nittos will cut it anymore,you will need an ET Street and line lock.
I would guess you have a Zexal/Torsion rear and not the Auburn which is weaker.With ET Streets and a good burn out 11s NA should be no problem.
You can always get a take out Zexal from SLP for $99 if the carrier goes south.I went thru 2 Auburns and now have the SLP take out Zexal but a 12 bolt is in the future.
<small>[ December 06, 2002, 07:10 AM: Message edited by: jfm ]</small>
