non LS1.... Tips for restarting an engine thats been sitting
I 'm ready to fire this bad boy back up but really don't want to spin a bearing. or hurt anything else and cost me the motor.....
Help Me....... PLEASE!!!
TIA
Aaron
I have seen engines that have been sitting around for ten years, & they started up w/o a problem.
Change your oil first.
Also, if you can get a oil pump primer, pull the distributor and get the oil pressure up in the motor before hand (that isn't a necessity, just something to do if you can).
Now, the most important thing. Get rid of the old gas. Gas that has been sitting for two years will be bad. Bad gas will form a gummy "varnish" this will stick valves and destroy motors QUICKLY.
We had a guy who had his motor in his jeep rebuilt. He left the motor at the shop, when he came to pick it up, we reminded him that the jeep had been sitting, and he needed to change the gas. He didn't listen. The motor stuck several valves during the break in period. He brought it back to the shop, and it reeked of bad gas. We showed him the deposits on the valves and explained that it was his fault. The shop fixed the motor again, and he cleaned out his tank. This time, no issue....
<small>[ December 06, 2002, 10:12 AM: Message edited by: J-Rod ]</small>
would you personally turn it that many times by hand?
