engine building question
Old Dec 6, 2002 | 08:37 PM
fast2001's Avatar
Default engine building question
On the 2001 6.0L engine, do you have to use a torque angle meter to torque the heads and main bearing bolts or can you use a regular torque wrench. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 6, 2002 | 08:52 PM
Redline-Motorsports's Avatar
Default Re: engine building question
If you are using stock bolts you should stick with the "torque to yield" method. If they where ARP parts you could torque them with a torque wrench.
