PRC 5.3L stage 2.5/cam
Old Apr 10, 2007 | 02:05 AM
jegten's Avatar
Question PRC 5.3L stage 2.5/cam
will these heads-
TSP PRC 5.3 2.5R heads 308 cfm - Milled to 62cc's from 64cc, 2.04 ferrea / 1.575 manley valves
work with a 228/232, .612/.600 cam?
i guess the concern is ptv. there is still some more info i need to get, but this is what i know so far about the heads, and that it ran really well with a 230/234, .595/.585 cam.
any feedback will be greatly appreciated.
thanks.
EDIT: just added the initial chamber before milling.
Old Apr 10, 2007 | 03:17 AM
PREDATOR-Z's Avatar
It depends on the LSA/ICL
Old Apr 10, 2007 | 07:09 AM
brad8266's Avatar
^^ What he said, it does depend on the LSA. LSA will determine your overlap amount once you have set your cam durations, the more overlap the tighter PTVC will be. I think that would be a decent combo but you will want to flycut the piston tops.
Old Apr 10, 2007 | 01:55 PM
jegten's Avatar
hey, pred and brad,
111+3lsa (108 ICL)
