Help me pick a cam!
Old Dec 9, 2002 | 10:56 AM
01ragtop's Avatar
Default Help me pick a cam!
I am thinking about getting a cam and I need your help. I have a 01 WS6 A4 vert. My mods are:
3.73
FRA
SLP 85 mm MAF
G2 Lid
Vig 2800
ET streets
SLP ory-pipe
HPP3 for shift points
I currently have run a best of 7.79 in the 1/8 with a 1.64 60' My goal is to be able to at least run mid 11's in the 1/4 with out any head work. I have a set of Hooker long tube that still need to be installed. So all that being said what would be the best cam for my car? Remember no head work!
Thanks, Larry
Old Dec 10, 2002 | 10:25 PM
OBSSSD's Avatar
Default Re: Help me pick a cam!
I'd highly recommend the Thunder 224 cam. Get it on a 112 if you want it a little rough or if you want it less tempermental get the 114.
I run a 224-112 with a 3500 stall. Your stall is actually a 3200. My numbers NA are 368/391 and 507/505 with the TNT 100 shot. The cam loves the juice!
Old Dec 11, 2002 | 09:20 AM
Ragtop 99's Avatar
TR 224 112 would be great.
I'd get rid of the HPP3 and buy LS1 Edit. You'll need it to raise idle speed and delete SES codes.
Old Dec 11, 2002 | 09:26 AM
98TAauto's Avatar
same as ragtop99 said
or TR 224/114 for a little better idle and less tuning for a A4
I run comp cams 224/224 114 cam .... take a look over on LS1speed also
like ragtop99 said, ditch the HPP3 and get ls1edit now!
Old Dec 12, 2002 | 12:35 AM
02SilverWS6's Avatar
What about the Hot Cam ? Check it here <----------------
Nice and cheap for the budget minded buyer. And it's GM hardware too!!
<small>[ December 12, 2002, 01:50 PM: Message edited by: 02SilverWS6 ]</small>
