ASA hotcam and piston to valve clearance?
Old Dec 9, 2002 | 02:01 PM
Gimp98TNT's Avatar
Default ASA hotcam and piston to valve clearance?
Will this cam have enough piston to valve clearance, heads are stock unmilled.
Also do you guys think it will make more power on a 150 shot than the standard hotcam.
<small>[ December 09, 2002, 02:16 PM: Message edited by: Gimp98TNT ]</small>
Old Dec 9, 2002 | 07:14 PM
Jelly's Avatar
Default Re: ASA hotcam and piston to valve clearance?
You will have plenty of piston to valve clearance with the ASA cam. All ASA engines are stock short blocks from GM with the same pistons you have in your engine from the factory.
Chris
