Hotcam????????Which heads?
Old Dec 12, 2002 | 10:58 AM
ponykila's Avatar
Default Hotcam????????Which heads?
OK guys just like the post reds I need to know what type of heads would mate best with the hotcam. I was thinking maybe the cnc ls6 heads but I would like a little input before I make my decision. Thanks guys
Old Dec 12, 2002 | 01:05 PM
MysticZ28's Avatar
Default Re: Hotcam????????Which heads?
I'll know in about 3 weeks how the LS6 CNC heads work with the Hot Cam ... providing the vendor gets the heads in <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" />
Old Dec 12, 2002 | 05:13 PM
02 Silver Z's Avatar
Sounds like a good combo to me! I doubt you would be dissappointed with them anyway.
Old Dec 12, 2002 | 05:20 PM
vettesarebetterthancamaro's Avatar
same here man its a good idea
Old Dec 12, 2002 | 05:30 PM
Nasty N8's Avatar
I think that combo would work fine, but those heads are a little overkill for that cam. A good set of stage 1 LS1 heads would complement it better. Our stage 1 heads are on special now in the sponsor section. $1100
Nate
Old Dec 12, 2002 | 06:38 PM
TheZman's Avatar
Check out Absolute Speeds stage 1X. I think i'll be ordering a set this spring, unless anyone has a better recomendation?
Old Dec 13, 2002 | 07:16 AM
BillWS6Formula's Avatar
Been doing some research and talking with people on the same topic and I'm hearing what others have mentioned - ie Stage 2, or ported LS6 heads are kind of overkill for the Hotcam with it's relatively mild lift and ramps.
Old Dec 13, 2002 | 11:14 AM
ponykila's Avatar
I dont think i understand what you guys mean by overkill. Will the Heads actually hurt howerspower or help horsepower. I will not get them if it will hurt horsepower. So if it will hurt horsepower what exactually do Ineed to do get a bigger cam. The responses are appreciated greatly thanks
Old Dec 13, 2002 | 01:23 PM
CW 99 Z's Avatar
I thought that the CNC LS6 heads done by LPE for GM were made for the ASA cam and their other low lift cams thats why they peak at like .550 lift. Someone correct me if I'm wrong.
Old Dec 14, 2002 | 12:08 AM
mobius's Avatar
it will not hurt horsepower, you could make more with a larger cam. the ls6 heads flow really well you cant go wrong with them. they are not really overkill in that you want the best flowing head you can get. but in relation to a stage 1 they are twice the money and you probably wont make much more power than a stage one with them but you wont loose power either. and with the 10.8:1 compression (if they are the assembled version) then you will pick up some power there as well.
Old Dec 14, 2002 | 12:47 AM
Nasty N8's Avatar
You may actually loose some midrange and lowend with that much flow and no cam to compliment it. You are deffinatly better off mathing the port work to the cam you use or vice versa than to go too big.
Nate
