cam w/stock heads
exhaust , 3.73`s, i`ll get the stall when i get the cam. def. want some lope
with that like 111 or 112 lsa what r my options , someone sugg. MS4 ?
that will get you the sound you want
.Now if your wanting something that pulls down low then the above cam is also suggested.
Now if you want a cam that makes the power up top and has a nasty cut up then go with the MS3, MS4, or T-rex. Those cams are harder to tune for and also will need larger stalls which some say brings down the driveability IMO its all about YOU, what do you see as fit for a DD or a good street car? Your the one thats gunna have to make that decision.
Hope this helps
Peace
B.J.
