TR 224 and base circle question
Old Dec 14, 2002 | 08:57 AM
Argon Z's Avatar
Default TR 224 and base circle question
tr 224/224 .561/.561 114
does any one know if i can run stock length pushrods (7.4") or is the base circle smaller which would lead to runnig longer ones
Also on a head cam car i should run hardend pushrods correct?
Old Dec 14, 2002 | 09:18 AM
Scalpel's Avatar
Default Re: TR 224 and base circle question
Have your heads been milled? If so, how much? That will determine if you can still use stock length hardened pushrods. If your heads are stock 7.400" length are fine. If your heads are milled 0.030" also, stock length are perfect too <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Dec 14, 2002 | 09:23 AM
Argon Z's Avatar
heads are not milled
Old Dec 14, 2002 | 09:34 AM
Scalpel's Avatar
Get a set of hardened stock lenght pushrods then and you'll be fine.
Old Dec 14, 2002 | 09:57 AM
Argon Z's Avatar
earlier i was told that aftermarket cam's often have a smaller base circle therefore a longer pushrod would be needed to get desired lifts.
Was i misled?
Old Dec 14, 2002 | 11:21 AM
Scalpel's Avatar
You are correct but the lifter can still accomodate the stock lenght p-rod with the 0.030" smaller base circle. You're fine. Don't worry about it.
