Swapping motors
Old Dec 13, 2002 | 10:54 PM
FrankSS's Avatar
Default Swapping motors
I recently had some engine problems and im in process of taking out my motor. I was wondering though, i was considering swapping to a ls6, and need to know if it would be cool to use the flywheel and balancer off of my motor now, or would i have to buy a new one(ie. is it internaly or ext. balanced). thanks
Old Dec 14, 2002 | 08:48 PM
LS1swap's Avatar
Default Re: Swapping motors
Both the LS1 and LS6 are internally balanced, so you could reuse the flywheel and ballancer. Any new engine will come with a ballancer on it. You do realize that you can basically make your ls1 int a LS6 if you want? An ls6 is basically an upgraded LS1. You could add a cam and put on ls6 heads & intake and have essentially the same thing. For allot less work and money
Old Dec 16, 2002 | 09:51 AM
FrankSS's Avatar
ya i was thinking about that, but the problem is that i have 2 broke rods and a messed up block, so i was probably gonna just go ahead and buy a crate motor and call it that. but thanks for rhe info
Old Dec 18, 2002 | 11:52 AM
AZLS1's Avatar
A crate motor may make things easier for you.
If you are planning major mods in the future this would be a good time to switch over to the LQ4 iron block.
