Final Rebuild Question
Old Apr 13, 2007 | 11:44 PM
santiago's Avatar
Originally Posted by brad8266
True but they are harder to maximize everywhere simply due to PTVC issues. there isnt much room to work with on a stock motor.head car. Now if you have some major piston relief thats a different story.
im gonna have to agree with you there. some good ported heads + big cam/lift on stock 346= fly cut ....too bad gm didnt put in reliefs stock!
Old Apr 13, 2007 | 11:47 PM
brad8266's Avatar
yeah man if they put stock pistons with .150 refief in that would have been sweet.
Old Apr 14, 2007 | 11:36 AM
BIG_MIKE2005's Avatar
Originally Posted by Cop Car
either the stock cam is fine or you should go bigger. a 224 cam is only going to net you a few tenths, and its not worth the money. if you are going to cam your car put a cam in that moves those lifters, not just something that mildly irritates the lifters.
Few tenths my ***. What are you talkin about?? You don't need some really expensive heads to make a 224 cam put down great times. All you need is a good port/polished set of heads & a good tune. That power with a good rear, tires & launch will get you in the 11's. Thats alot more than a few tenths & you'll have power longer.
Bigger cams might make more peak power, but they don't make power as long or as smooth.
