Quick ? about replacing stock rocker arms
Thanks in advance for any help given. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
You didn't have to post this question for me--I just came over here to do it myself. Thanks!
Here's another question:
If I only replace one rocker arm, how do I go about torqueing the one nut down?
The service manual gives a procedure for torqueing all 16 involving putting #1 at TDC and so on. Do I need to loosen all 16 and follow the service manual procedure? Or...?
Thanks.
<strong>A friend of mine just found a needle bearing in his oil recently when he was changing it. It's obviously from a rocker arm. My question is this, once he finds the faulty rocker arm, can he just replace that one, or does he need to replace all 16?
Thanks in advance for any help given. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">IF THE CAR YOU ARE WORKING ON IS BY ANY CHANCE UNDER WARRANTY, TAKE IT BACK TO THE DEALERSHIP AND THEY WILL REPLACE ALL 16 FOR YOU, GM HAS A SERVICE BULLETIN PERTAINING TO THIS EXCACT PROBLEM THAT YOU ARE FACING AND REPLACES ALL 16, AS FAR AS IF IT IS OUT OF WARRANTY ITS UP TO YOU WETHER OR NOT YOU WANT TO CHANCE IT WITH JUST ONE ROCKER. I DONT KNOW THE CAUSE OF THE BEARINGS COMING OUT BUT I CAN LOOK AT WORK TOMMOROW AND LET YOU KNOW, HOPE THIS HELPS <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<strong>Hey UnbelievabLS1,
Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">THE PROCEDURE YOU ARE TALKING ABOUT APPLIES TO THE LT1 NOT THE LS1 LT1'S ARE SET TO ZERO LASH AND LS1'S ARE TORQUED TO 20LBFT AND TURN THE MOTOR OVER ONCE AND RETOURQUE TO 25LBFT HOPE THIS HELPS <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
