Hotcam shims question
Old Dec 19, 2002 | 10:40 AM
Scalpel's Avatar
Default Hotcam shims question
Are the shims that come with the hotcam necessary to install with the kit? Thanks.
Old Dec 19, 2002 | 11:25 AM
RoyO's Avatar
Default Re: Hotcam shims question
I didnt use the shims when I installed that cam in my car.
Old Dec 19, 2002 | 04:29 PM
Scalpel's Avatar
Any others with any input? Thanks.
Old Dec 19, 2002 | 09:16 PM
O6blues's Avatar
The copper piece is also a spring locating device, similar to a spring cup. To maintain the proper pressure at the installed height of the valve spring it is usually necessary to use these shims/locators --- assuming you are using stock length valves and stock components. Keeping the spring from moving around in the seat is critical to spring life. This piece also prevents unnecessary wear on the aluminum cylinder head.
