Quik Question ----Need Help Soon!!
Old Apr 13, 2007 | 08:51 PM
tatasta's Avatar
Default Quik Question ----Need Help Soon!!
I have ordered a TR 224 112lsa cam. LS6 heads or 5.3s? That is the question.
Would PTVC even be a factor in the 5.3 head with the 224?
Thanks in advance,
tatasta
Old Apr 13, 2007 | 09:29 PM
02silvaZ's Avatar
may have a slight clearance issue with the 5.3 but then again might not be a problem at all, both heads will increase compression ratio but the LS6 will outflow so i say go with LS6 heads
Old Apr 13, 2007 | 09:35 PM
brad8266's Avatar
PTVC shouldnt be an issiue with either of those heads unmilled. I would run the LS6 heads milled down and use a .040 head gasket.
