the engine is sticking at 2000 rpm after heads/cam install? help.
after i installed heads, cam, fast 90mm, NW 90mm TB, QTP headers, Borla catback.....etc without tune ( i did let the car idle at 1000 rpm by screwing the TB screw) the engine is sticking some times while driving at 2000 rpm, is that because of the TPS and the PCM needs tunning how can i fix that?
thanks for help.
thanks for help.
