Anyone running ARE stage 3 ls6 heads
Old Dec 27, 2002 | 09:24 PM
theblur98ss's Avatar
Default Anyone running ARE stage 3 ls6 heads
Just curious if any of you are running stage 3 ls6 heads from ARE. I'd like to hear dyno #'s or track times or even flow #'s.
Old Dec 27, 2002 | 10:58 PM
SPEED DOG's Avatar
Default Re: Anyone running ARE stage 3 ls6 heads
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by theblur98ss:
<strong> Just curious if any of you are running stage 3 ls6 heads from ARE. I'd like to hear dyno #'s or track times or even flow #'s. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am. See my sig below. Don't have track times but the dyno numbers speak for themselves. The engine is quite new (1200 miles or so) and we're still sorting it out. But this should give you some idea.
Hope this helps.
Old Dec 27, 2002 | 11:48 PM
Quickin's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SPEED DOG:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by theblur98ss:
Hope this helps. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey bro,
Got a question. I have an ARE 436 with a 242/242 .610/.610 114 lsa cam. What is your cam size and compression? My car was dynoed for the forst time 2 weeks ago with the factory fuel pump and it pulled 480 RWHP just before hitting 5000 RPM when the fuel pressure dropped 3 psi, then as soon as it passed 5000 RPMs it quickly lost 10psi and the run was aborted.
My car will be re-dynoed tomorrow.
I also am wondering what your cam is because I'm curious to know how my idle quality will be.
Thanks
Old Dec 28, 2002 | 06:47 AM
SPEED DOG's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Quickin:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SPEED DOG:
Thanks </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cam is about the same: slightly higher lift. Wade told us the CR was 11.5, which actually may be a little high for ordinary use. We've had to be very careful about timing, and fuel quality.
As far as I know, we've not had any problem with fuel pressures. Now that you mention it, however, I think I'll check it with a dyno run.
The idle is hard to get right; we needed to drill a 13/64s hole in the TB, and play with the follower settings via LS1 to get it reasonably stable (also raised it to 1050rpm). Actually, idle isn't the issue: the problem is that letting off on the throttle allows the butterfly to close, the rpm's drop rapidly to below idle, and the engine dies. We've eliminated that per the above, but are left with a little bit of a "hang" when the engine is coming down. I'm not sure if we'll be able to get that out or not.
Mike Norris is great, and should be able to help you with all this. I'm actually thinking of getting the car to Toronto next Spring to fine tune my setup. If I can't get it there, I may drive to Orlando.
Give Mike my regards.
Best of luck.
Old Dec 28, 2002 | 07:41 AM
mikey's Avatar
LS1TECH Sponsor
<strong> Just curious if any of you are running stage 3 ls6 heads from ARE. I'd like to hear dyno #'s or track times or even flow #'s. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where are you in PA? I have a set of ARE LS6 heads going on an 02 Vette mid Jan. If you're close enough stop in and take a look at them. Maybe go to the dyno as well.
Mikey
Old Dec 29, 2002 | 12:23 AM
I'm on the other side of the state Mikey...hour north of Pittsburg. Wish I was closer but I may make the trip out in the spring for some tuning or maybe even have you make the trip over if there is enough interest.
Old Dec 29, 2002 | 07:26 AM
mikey's Avatar
LS1TECH Sponsor
<strong> I'm on the other side of the state Mikey...hour north of Pittsburg. Wish I was closer but I may make the trip out in the spring for some tuning or maybe even have you make the trip over if there is enough interest. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I can make the trip if you get like 5 people that want the tuning done. Good luck with your car. I'll post the results on this Z06 when finished.
Mikey
