Mobil One Oil Question
On the flip side, I am running 15w-50 because I have both a high volume oil pump and a need for it. But don't run the thicker stuff until you are both set up for it and need it. Applications that produce a lot of torque, such as nitrous/forced induction/stroker motors should probably use the thick stuff since more bearing protection is needed in those cases.
Moving to Internal Engine...:burnout:
