6.0 Liter bore
Also, if you go much above 4.030, there would not be any cylinder wall thickness left if you had to rebuild motor. I am doing a 4.060 bore with 4.125 stroke for 427 cubes.
Prostock John only has a 4.060 bore also, matched with a 4.075 bore for 422 cubes.
MTI 427 C5 Roadster
Rich, to answer your other question, the iron block is definitely going to add about 75 lbs to a car... perhaps 80 lbs.
I'd go 4.030 for most iron blocks, if you can find one with minimal coreshift you can go bigger like mine.
