Took the heads off - Clean up?
Old Apr 17, 2007 | 09:28 AM
jinxedz's Avatar
Originally Posted by Studytime
That was meant in reference to the TR230 with 11.1 SCR- not valve/piston clearance in any way.
I agree, measure with a degree wheel and know for sure.
jinxedz, if you're trying to decide between a .020" or .010"- go with the .020" mill. Compression is your friend. It'll even idle better (smoother) if you can get the compression up some.
Ben T.
great, thanks.
If I mill, will the Hardened TSP 7.4 pushrods I have be adequate, or will I have to go smaller?
Old Apr 17, 2007 | 09:41 AM
PREDATOR-Z's Avatar
You can mill .025 with stock gasket and still have good clearances, and that way 7.400 will be perfect on stock lifters.
