ls6 cam questions?
sdpc couldnt tell me what length pushrod i should go with when these cams go in, has anyone done this swap? im new to ls series motors and i dont know if the 5.3 i have has the same basic parts as my uncles 6.0.
the ls6 cams have a smaller base circle, and that is the reason for a longer pushrod, correct? could i just subtract the base circle difference and add that to the pushrod length?
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Better to be safe and on the money then using a set of dial calipers. Either way will work, but it will be closer with a nice pushrod checker.
